ring gap for 250 shot
Old Apr 22, 2009 | 03:38 PM
02anti_vnm's Avatar
Default ring gap for 250 shot
I'm putting my forged 347 back together and I'm ready to gap the rings and just need a little double checking
The pistons and rings are both made by mahle they're flat tops with valve reliefs
I'm going to be spraying a 250 direct port on it and I called mahle and the man said I should gap the top one at .030 and the second one at .023 does that sound about right? I trust the guy just wana make sure
Thanks for any help
Old Apr 22, 2009 | 06:05 PM
WE TODD DID's Avatar
Thanks for any help
I'm assuming its a 4" bore? If so, .030 is good on the top ring, but the bottom ring need to be gapped larger than the first.
Old Apr 23, 2009 | 10:21 AM
02anti_vnm's Avatar
Bump....
Old Apr 23, 2009 | 11:20 AM
02anti_vnm's Avatar
Its a 3.9 bore but y does the bottom ring need more gap I'm new to building an engine and new to nitrous. I'm just learning as I go
Old Apr 23, 2009 | 05:25 PM
If the second ring gap is smaller, it can result in getting gasses stuck between the rings. The engine will actually make a little more power with a larger second ring gap. I do mine about double of what the top ring gap is, but really anything larger than the top will be fine.
