Wet kit with Speed Inc aftermarket rails
Old Apr 24, 2009 | 09:34 AM
Juiced347's Avatar
Default Wet kit with Speed Inc aftermarket rails
I am planning on ordering the speed inc budget rail kit for my Ls1 car.
http://www.speedinc.com/catagory.cfm...%20/%20Cooling
How will I tap into the rails for my harris speedworks Wet kit? Currently it's connected to the test port on the stock rails...
Thank you.
Old Apr 24, 2009 | 11:36 AM
Chris@NitroDaves
Guest
Posts: n/a
I beleive the fittings that are used for those rails are 3/8. You could get a 3/8 x -4 fitting for the pasenger side of teh rail and pull fuel there. Other than that you will need to get a T fitting to put on the drivers side and pull fuel from there.
-Chris
