150 to 175
Old Apr 28, 2009 | 12:45 AM
PONTIAC SLP's Avatar
Default 150 to 175
Hi , i tuned my car for 150HP , can i spray 175HP with same tuning without changing the timing ? and how about 200HP ?
Old Apr 28, 2009 | 06:14 PM
hey anyone can answer ? it's necessary adjusting the timing ?
Old Apr 28, 2009 | 06:19 PM
dnkynrbk's Avatar
I would drop the timming 2 degrees for every 50 shot and run a TR7 plug if you do a 200 shot run a TR8 plug at least. Where is your timming currently at?
Old Apr 28, 2009 | 06:44 PM
i don't know what is my current timing i forget , but why i should run with TR7 ? always i run with TR6 !
Old Apr 28, 2009 | 06:46 PM
Mike@HSW's Avatar
What plugs are you currently running, TR6? Go with a colder non projected tip if thats the case and the timing will depend on what you saw from you current setup. You may or may not need to pull anymore. All depends on your car.
Old May 2, 2009 | 10:45 AM
yes TR6 , what u advice me to run with for 175?
