Forged 402 - Okay for a big shot?
Old Apr 30, 2009 | 10:23 PM
HotWhipT/A's Avatar
Default Forged 402 - Okay for a big shot?
Its a forged 402 from TSP.
Upgraded ARP2000 rod bolts
ARP head studs
cometic gaskets
How are the rings? They are TSP's exclusive Total Seal Ring set.
4.010"+.005", 1.5mm Plasma Moly Top, 1.5mm Napier 2nd, 3mm Oil.
Max I would probably ever spray is a 250 shot. Could the motor handle that? What is the limit?
Old Apr 30, 2009 | 10:27 PM
CaMaRo67RS355's Avatar
should be able to handle a 250 shot i wouldnt go much higher if any thought
Old Apr 30, 2009 | 10:29 PM
gsxr1k2's Avatar
Jon or Matt should be able to tell you in a flash.
Old May 1, 2009 | 08:17 AM
BlackTA96's Avatar
You'll need to upgrade your fuel system for a shot that big.
Old May 1, 2009 | 09:04 AM
Chris@NitroDaves
Guest
Posts: n/a
AS stated above as long as you have enough fueling to cover that amount of shot you should be able to spray the car without a poblem.
A typical off the shelf non nitrous forged piston should handle up to around a 250hp shot.
-Chris
Old May 1, 2009 | 09:24 AM
Lt1Porsche's Avatar
250 shouldnt be a problem
Old May 1, 2009 | 07:41 PM
HotWhipT/A's Avatar
-Chris
Cool man. I breifly talked to Dave at TAD last friday. I'll definately be coming to you guys when I get ready for nitrous.
