Hooking up fuel on ls1 zex direct port
Old May 5, 2009 | 09:11 AM
MY99TAWS6's Avatar
Default Hooking up fuel on ls1 zex direct port
I am installing a zex direct port system shortly on my car. I have lonnies billet rails. I am wondering how to hook up fuel supply to nitrous since kit normally just puts fitting where shrader valve is on factory setup.
I do have a boost referenced regulator setup .So do I have to get some fitting to t into the main fuel line feed to the drivers side rail or can I take my fuel off the fuel regulator?
Old May 5, 2009 | 11:46 AM
Chris@NitroDaves
Guest
Posts: n/a
You could take the fuel straight off the regulator as long as it's a outlet port.
-Chris
