what would the best nitrous controller for a 2 stage on this setup
i have the 2 stages and both are wet kits and have the mallory 685 box for retard purposes...but i would like to know what would be the best and/or easiest for starting either both or the 2nd stage of nitrous???? right now i just use the first stage and then hit the 2nd stage after 2nd gear is achieved...but i would like a more accurate way of using the nitrous without any extra buttons to push for activation...o yea the first stage is on w.o.t tps..
any suggestions would be greatly appreciated..
thanks
thanks
I tried hitting the second button last year, and it doesn't really work unless it's on the steering wheel.
My suggestion would be the MicroEdge from HSW. It has a gear lockout option, and a timer option. You can't beat the price either.
Since the mallory already has a windowswitch there are a couple of options. We have a digital delay box that you can use to delay the second stage until you want it to come in. It cost 99.00. Or we have our digital dual stage window windowswitch with built in TPS activation and gear lock out features. With the gear lock out feature you can set the second stage to come in at what ever gear you want. This unit is completly sealed so you can mount it anywhere. Its 100 percent water tite. This box is only a 110.00
Dave
Dave
