Question about nozzle placement..
Old May 6, 2009 | 08:50 PM
rickou812's Avatar
Default Question about nozzle placement..
I am running in SD mode, so I don't have a MAF and I have a 4" cone filter attached to the throttle body.
I would like to install the nozzle in the end of the cone filter, but have concerns about how it will work since the nozzles are designed to spay a 90 degree pattern which would make it spray right into the filter material.
Would this work like this or should I find a nozzle that will spray straight out the tip?
Old May 6, 2009 | 09:14 PM
rickou812's Avatar
Here is a picture of what I am trying to explain:
Old May 6, 2009 | 09:30 PM
blackls1ta00's Avatar
id put it in the throttle body,i have an sd tune also i got a coated hard plastic straight pipe about 6 inches long with rubber couplers on each end,i installed nozzle in the pipe and face towards throttle body works great,good luck.
Old May 6, 2009 | 10:48 PM
Nitro Dave's Nitrous Outlet's Avatar
The best fit would be one of our plates. If that is not in your budget and you want to stick with a nozzle one of the NX STD nozzles would work. Its a stainless nozzle that blows strait out of the tip.
Dave
Old May 6, 2009 | 11:00 PM
rickou812's Avatar
Dave
Do you carry the NX STD nozzle, if so, how much?
Thanks
Old May 6, 2009 | 11:07 PM
Yes sir. Here is a link. We need to update the picture. They are now stainless and silver.
http://www.nitrousoutlet.com/catalog...product_id=949
