New best N/A ......
Old May 16, 2009 | 07:54 AM
ATVracr's Avatar
Default New best N/A ......
The GBR car went 10.78 @ 135 last night.
With no dyno time Shiz was getting it dailed in pretty fast.
We made 3 passes...
13.0 ..... Let off 1/8 th to make sure everything was good (brakes, susp)
Next pass ... ran it out went 10.98 @ 133 (1.83 60' spinning)
3rd pass .... was the 10.78 @ 135 (spun again 1.82 60')
We have a few things to work on this weekend, should be ready for some N20 next weekend.
Old May 16, 2009 | 07:58 AM
FastBlackTA's Avatar
Dude that car is going to haul ***..........
Old May 16, 2009 | 08:05 AM
ATVracr's Avatar
I hope so.... I was impressed with the MPH.
Old May 16, 2009 | 08:18 AM
I am impressed too.
Let me know if you guys run next week and where.
Old May 16, 2009 | 09:44 AM
MADMAN's Avatar
LS1Tech Sponsor
Nice get the bottle on it and it will fly.
__________________
www.madmanandcoracing.com
225-343-9029
Old May 16, 2009 | 09:45 AM
ShiznityZ28's Avatar
mir on sunday for the 275 race.
After look at the final run log we put a little timming in and the car leaned out . We need a couple more NA runs so i can figure out does it like the timming or being lean. Its leaner and more timming than we have ever ran it NA. last years tune needed 30lb/hr of fuel above 4K or so.
Old May 16, 2009 | 10:29 AM
ATVracr's Avatar
Sunday @ MIR
Old May 16, 2009 | 11:34 AM
Phil99vette's Avatar
7 Second Club
Looks good MPH wise, what do you need to do before you hit MIR?
Old May 16, 2009 | 12:42 PM
BAKED's Avatar
What does your car 60' on motor?
Nice N/A times for a nitrous car!
Old May 16, 2009 | 01:15 PM
02Z28's Avatar
Whats your motor setup?
Old May 16, 2009 | 02:50 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Especially with the glide.
Old May 17, 2009 | 12:00 AM
ATVracr's Avatar
We need to scale the car, change up the vaccume pump (suckin alot of oil)
We are going to go to Capitol again next Friday make 2 more motor passes then turn on the 1st kit.
You almost ready to run yet?
Old May 17, 2009 | 01:00 AM
1.8 spinning with the t brake going to 5K we didntt get to try any higher since the track sucked and our supention was probably not perfect. we will scale/square it this week.
Old May 17, 2009 | 01:02 AM
HKE 396 iron block. Perf Indiuctions C5X heads/ PIS 2 piece intake.
GBR( ATV and I) Tuned on a fast xfi. It will go a 10.5 and 138mph next time out id guess. The fuel log showed the car wanted more fuel and never peaked. it needs to be shifted 500 rpm higher on the motor. he was using the nitrous shift points.
Old May 17, 2009 | 03:55 PM
Robert56's Avatar
135mph n/a is good. Why can't you guys hook up n/a, are you running a different tire or the entire car is not set-up for n/a launching? that's prob a low 10.xx car should you get it dialed in completely for n/a running? Good luck and let us know how it came out.
Robert
Old May 17, 2009 | 08:45 PM
It was friday night at capitol ( known as crapitol by the locals) and honestly we didn't even do anything other than adjust the panhard for the new ride hight. we only spun the tires 2X all last year and that was on the 350 shot. spinning will not be an issue
Old May 18, 2009 | 12:00 PM
Nitro Dave's Nitrous Outlet's Avatar
Congrates... Cant wait to see some Nitrous passes.
Dave
Old May 18, 2009 | 01:59 PM
Fireball's Avatar
Like I said on EFA...its gonna haul the mail on the jug
Do you know what you're gonna change? I went thru that when I first started with mine and fixed it...
where are you pullin vacuum?
do you have an air/oil separator between the pump and the engine?
Old May 19, 2009 | 08:06 AM
We left it the same as last year( pass front valve cover near the pump) but when we changed valve covers the new ones had a -12 oring port in them so we screwed the fitting directly in. Last year we had about a 3" stand on it then the fitting this must have been enough. we are moviong it to the valey cover so we can weld in a bafle .
Old May 19, 2009 | 08:25 AM
Fireball's Avatar
be careful...tyson and I tried the valley cover on mine (with an aluminum bafflle) and it sucked serious oil becuase the cam is throwing alot of oil upward. I moved mine on the front of my valvecover where yours was and its been great...not pulling really any oil...and there really isn't any standoff either
I do use one of those moroso oil-air separators inline between the valve cover and vac pump inlet just to be sure, but its been dry (just condensed oil and water vapor)
