My install and purge pics
Everything is hidden except for the noids.. Bottle, heater and opener in the spare tire area and the window switch and relay mounted behind the glove box. Whaddaya think? Any suggestions?
I'm loving it. Just put in some TR6's and ready to spray it tomorrow if it stops raining.
Big thanks to MnypitZ for the help with the install.
Get a plx wideband, they work well and the gauge is pretty good looking.
I just used the standard mounting brackets and put them on bolts already on the engine. One already had a nut and the other was just a bolt that I put a nut onto. Barely had to bend the brackets at all, only a little to make the fuel noid sit level.
I really wanted the noids under the FRC's but they're huge and wouldn't fit. I left enough length in the wire to hide them in the nose, but I sorta like them where they are.
Yeah, I wish.. thats what happens when you run it without the pressure senders plugged in. Its all set up now and runs at a constant #60 at idle and part throttle, full throttle it goes to #55.
The driver seat picture is really cool.
