Timing Pull Resistor Trick !
Old Sep 13, 2009 | 02:31 PM
  #41
Twotonefreak's Avatar
I'm using the timing tricker myself and it works great. We only had to wire in a relay and my tuner modified the tables. Cheap and effective.
Old Sep 14, 2009 | 07:51 AM
  #42
JAX04's Avatar
yeah, i think im actually going to do this for another application as well, alot of our vehicles are byfuel here at work and have an extremely shitty and conservatice tune on them, so when they switch to CNG they run like **** with no timing. i may use this device to pull timing back out when it switches to regular gasoline, and use the iat vs spark table to adjust how much is pulled out. should work.
Old Sep 17, 2009 | 05:09 PM
  #43
slammin86's Avatar
Originally Posted by slammin86
Can you post these or pm them to me?
Originally Posted by Robert56
That table Power adder vs IAT, or what ever it is called. We had tried this for fueling the before the MAF style kits. Unless you were getting a good cold reading, it didn't work well, and also the temp reading could vary. What the table really is, is a PE multiplier that gets added onto your WOT Power Enrichment multipier. I do have all the numbers on what multiplier numbers equal what a/f ratio should anyone decide to target a temp and use this table. Another way to fuel the Dry shots.
Robert
Any way you could post these or pm them to me?
Old Sep 17, 2009 | 05:26 PM
  #44
Robert56's Avatar
yes i will. i am away from my notes right now so a little later today. If I forget, just remind me with a PM, please, lol.
Robert
Old Sep 24, 2009 | 08:13 AM
  #45
YURVIEW's Avatar
Originally Posted by YURVIEW
i notice the 750ohm resistors come in several different Watts.... is there a certain Watt 750 resistor to use?????
bump for an answer, Please. gonna install the kit this weekend would like to know. thanks
Old Sep 24, 2009 | 10:54 AM
  #46
Jazz-LT1's Avatar
I hope someone else will respond to this Wattage question, but here's a guess.
power in watts =(current in amps)squared x resistance in ohms
I'm not sure the current at the sensor however... anyone have that from a meter? It should be VERY low....
Old Sep 24, 2009 | 02:17 PM
  #47
waltsfastz's Avatar
Yeah I bought some resitors last nite and I got the smallest wattage that radio shack had(Forgot what they were) I couldnt find a 750 Ohm resistor so I bout some 680ohm and 68ohm. in sure 748 is close enough to 750(given how they are ratied to 5% accuracy anyways.
HOWEVER I have a question:
Im going to mout my realy close to the PCM. Which wire(s) and location in the one whe are looking for here from the IAT sensor?
Thanks
Old Oct 2, 2009 | 08:37 AM
  #48
YURVIEW's Avatar
Ok why would this not be working?? Did this mod Thai wkend have not had chance to put ohm meter on it. Wired thru relay to n2o switch as portrayed by the diagrams. Just clarify, I cut the tan wire & ran from IAT to 87a and the other end from pcm to 30. Is that correct?? Car struggling to idle and running Very rich!!
Old Oct 2, 2009 | 08:03 PM
  #49
slmawi's Avatar
thats correct
does switch work is "ON" ?!! cheak all wire from switch of is OFF
Old Oct 2, 2009 | 08:53 PM
  #50
YURVIEW's Avatar
^^^ not quite understanding all of your message. But I disconnected the relay and reconnected the tan wire back together. Car still running bad. Like it has never been tuned. Gonna go thru and check all my sensors but I don't see how, I didn't mess with any others.
Old Oct 3, 2009 | 12:20 AM
  #51
Gary Z's Avatar
Originally Posted by JAX04
...so is it instant that the computer pulls the timing, or does it take a second. i would hate to shoot a bigger shot under WOT and wait say 3 seconds for the timing to be pulled. or am i not thinking correctly at all?
This is a valid concern. I'm not sure about other PCMs but the 2002 PCM samples the IAT sensor twice per second so the delay is one half second or less. This is not a problem if the timing-tricker relay is directly enabled by the nitrous active switch and not through the WOT switch. If the TT relay is enabled through the WOT switch then a half-second delay may be introduced whenever you lift. This would be a significant problem in a manual transmission car.
Old Oct 3, 2009 | 08:56 AM
  #52
On my 98 I have the "tricker" going active on the WOT switch and no issues thus far. I haven't data logged anything, but on they dyno we have no zero knock and no lean spikes.
Old Oct 3, 2009 | 01:44 PM
  #53
Gary Z's Avatar
If the timing-tricker relay is enabled through the WOT switch then the worst case would be if the tricked IAT is used to pull timing and to add fuel. There then could be a half-second delay before timing is pulled and fuel is added and you would be spraying during the delay. This is a lesser problem for auto cars that typically remain at WOT throughout a run. Similarly, the problem would not appear on a dyno.
Old Oct 3, 2009 | 03:33 PM
  #54
waltsfastz's Avatar
Ive got mine wired to the nitrous arm switch, So when the arming switch in on the realy is enerjized. But still, Does anyone know what location these 2 wires are on the pcm? 02 model
Old Oct 5, 2009 | 04:31 PM
  #55
Tweak213's Avatar
ok so using a resistor to pull timing for n2o cars how about the said adding timing for na cars any more info on this
Old Oct 6, 2009 | 06:22 PM
  #56
Sinist54's Avatar
Has anyone using this method had any problems with the IAT itself or know of any issues it may cause?
I am in the process of installing a NOS plate and deciding on either the 'trick' or having a second PCM tuned specifically.
Old Oct 11, 2009 | 12:18 AM
  #57
n20z28's Avatar
so when useing IAT trickercdoes it just pull timing at wot? or does it pull througout and add fuel?
Old Oct 11, 2009 | 07:42 AM
  #58
slammin86's Avatar
Depending on how your tables are set up. In stock form it will likely pull timing whenever it is activated. Thats why you wire it up so that it is only activated when the system sprays.
Old Jun 18, 2011 | 09:03 AM
  #59
Bowtiedford's Avatar
just subscribing, good info.
Old Jun 28, 2011 | 05:49 PM
  #60
00silverGTP's Avatar
anymore expirence with this??
