Timing Pull Resistor Trick !
Old Aug 25, 2011 | 12:49 AM
  #61
OneBadRR's Avatar
Bringing back from the dead, have a wiring diagram in front of me, I have no purple wire, Looks like black/white ground, yellow signal, pink ignition, tan IAT sensor, and black which is part of the IAT circuit which grounds in the pcm. Would I just exchange the purple wire in the diagram for the black attached to the IAT? it doesn't look like my IAT has a reference, just sensor and ground.
Old Aug 25, 2011 | 05:52 AM
  #62
SargeZ06's Avatar
What year and model is the car?
Old Aug 25, 2011 | 10:00 AM
  #63
OneBadRR's Avatar
2002 Escalade, LQ9.
Old Aug 25, 2011 | 11:07 PM
  #64
OneBadRR's Avatar
Here's a shot of the MAF/IAT on the diagram
Old Aug 26, 2011 | 05:50 AM
  #65
SargeZ06's Avatar
To convert your wires to the first diagram, Your (A)signal wire is Black, and your (B)ground wire is Tan.
Old Aug 26, 2011 | 08:55 AM
  #66
OneBadRR's Avatar
Thanks! That's exactly what I figured.
Old Oct 25, 2011 | 01:24 PM
  #67
WS.666's Avatar
Resurrecting again...will this work on a 2000 Grand Prix GTP using a LQ4 MAF/IAT? I'm assuming it would, just not sure if the PCMs are similar or not.
Old Oct 26, 2011 | 09:02 AM
  #68
bufmatmuslepants's Avatar
Anyone know the tables on iat vs resistance and timing pulled for lt1? More specifically obd1?
Old Apr 7, 2013 | 02:25 PM
  #69
stang_kllr's Avatar
what kinda resistor would you want to use to add timing instead of pulling it. I rather be on the safe side and run a nitrous tune, and when im n/a ill add timing. without looking at hp tuners and seeing at what time, how much voltage the knock sensor is picking up, if any, I wouldn't trust just pulling 3 degrees across the board on spray, as timing will vary during the hole shot. maybe im just confusing myself, but I want to do this and I want to get the greatest benefit while being safe, as im going to be running a 200 shot. I know this thread is also old as $#!+
