Nitrous bottle ?
Any insight on this.
http://cgi.ebay.com/ebaymotors/BILLE...spagenameZWDVW
Does this have to be professionally installed, if you look in the picture it has like to allen head screws that are between the vlave and the bottle. That is what I need, so I can read the bottle pressure with the bottle closed.
http://nitrousoutlet.com/catalog/pro...roduct_id=2148
I will give it a try. Is there a seal or anything speacial i need to do or use?
Like said earlier, make sure its empty and put a little bit of lube on the o-ring when you go to re-torque the valve to prevent the o-ring from shearing. Also try and remember that the bottle should technically be "oxygen clean", IE don't get **** in the bottle.
Rick
I use a cresent wrench and a 4 lb hammer to change valves. And I will empty your bottle if your willing to ship.
Rick
I bet that valve is on there something tight, the hammer is what porablly end up using.
