anyone ever use their purge as a 2nd stage dry shot?
i am running a nx wet kit, it came with a purge solenoid but i dont use it, just purge thru the motor, any reason why i couldn't use the purge solenoid for a 1st stage dry shot? just need a line and a jet holder, it would be super easy to set up.
thinking a 100shot dry into the air filter and a 150 or so wet a second or so later.
Parish, I know fireball did something like this a long time ago. I would go for it. if you do it, let me know what fitting you buy from NOS to hold the jet and spray into the lid
Thanks,
Glenn
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks,
Glenn
Thanks,
Glenn
Thanks,
Glenn
also some kind of control, now that i think about it i probably wouldn't use it as a 2 stage but more as an incab adjustable set up. spray it all out of the hole(with window switch and stall) but be able to choose at the flip of a switch weather to run no nitrous, or a 100dry or a 150wet or both the 100+150. or just save the extra shot for if it looks like i am going to loose a race.
