Nitrous friendly and NON-friendly cams
Phillip
All motor
10.93 @ 124
Nitrous
10.70 @ 127
10.71 @ 130
Usually the nitrous comes on strong but the car felt lazy on the juice. All motor it had a good pop and felt strong. My cam specs 232/238 111lsa.
I can only think that the car is:
1) Knocking(I doubt it)
2) Fouling the plugs running rich
Phillip
As for what's going on with your car, I think I'm confused by your posts just what it is you're looking for. Have you sprayed this cam before, and you're just trying to find out why your performance was down this time? Or is this your first time spraying it, and you can't figure out why the nitrous doesn't perform like it should?
Knowing what I've read from your posts so far, it sounds kind of like you're running a wet kit with low bottle pressure. I made a pass with the 150 jets a week or so ago with 850-900psi on an NX wet kit, and it acted about like an 80-90 shot. Bottle pressure plays a pretty major roll...
Phillip
you shoulda made way way more mph than that. my car makes 118 motor and 130-131 on the 150, so you should been close to the 140 mark on the 150.
I was only on a 100 shot. Before It would pick up 12-14mph. I know something is amiss but we'll find it out shortly. 10.93 @ 124 all motor is going to make for some sick nitrous times.
Phillip
i would verify your solenoids are all coming on, check electrical connections, if this is an older system check the inlet N20 fitting into the noid to make sure the screen is not clogged. If your car is running pig rich you would notice the lack of performance as well as tons of black smoke out the back.. are you seeing this? what do your plugs look like? if they are black and smell like fuel then they might be fouling and again check for proper N20 flow. Change the plugs and gap them to .040 i use R42LTS AC plugs with great sucess over the years.. the TR6's work well too. if this is not a fogger system have a buddy hold your nozzle/ ring whatever and hit it in open air to see how the spray pattern looks. also if your using a fuel pressure switch take it out of the loop to make sure the switch is not going bad... they are known culprits themselves.
i take it you have used this system before with the desired results? or have you changed anything recently?
i hope this gives you some ideas to check...
