Long story short, put a NX universal wet kit on buddy's car not too long ago took it to the dyno, sprayed it till about 6000 before it started to go lean, so we took it home, put a fuel pump in it, took it back to the dyno and now the kit will only spray until 4500 each time, it consistently shuts off at 4500 rpm. Bottle pressure and fuel pressure were good on these runs. Limits in the window switch are still correct 3200 upper limit 6500. Also b/w dyno sessions my buddy had a local circle track guy put a fuel pressure and nitrous pressure gauge in which he used teflon tape for instead of the red loctite provided, and we had to fix a bad fuel leak where he spliced in to the fuel line, but I doubt any of this would have caused the problem.
My question is could the window switch be showing the correct limits and actually telling the nitrous to cut off at 4500?? Like a bad signal or something? I am lost, any help would be greatly appreciated
