Dedicated Fuel System?
hes building a 440......he needs a standalone. or a lot more intank pump.
Basically what you will need is.. Holley low pressure "Black" pump, adj. FPR, low pressure fuel pressure safety switch. a bunch of fittings, 3/8 or 1/2 fuel line.. about 12 feet of it. I dropped the tank, cut a 3/4 hole in the top near the big hole for the sending unit and fuel pump.. flared a tube and connected a 90 to it, rtv'd a rubber washer to seal top and bottom against the tank and tightened the whole assembly.
Basically made my own pickup tube for the holley to feed off of.. piece of cake.. no need to buy big expensive pumps and all this "jazzy" crap.. we've been running nitrous this way for Eons.. Might be tho old way of doing it, but its tryed and true.. Only downside to this setup is that if you want to run racegas through youre nitrous, you have to run it through youre motor as well.. Wich I dont mind at all..
If yall want pics, I got em Basically what you will need is.. Holley low pressure "Black" pump, adj. FPR, low pressure fuel pressure safety switch. a bunch of fittings, 3/8 or 1/2 fuel line.. about 12 feet of it. I dropped the tank, cut a 3/4 hole in the top near the big hole for the sending unit and fuel pump.. flared a tube and connected a 90 to it, rtv'd a rubber washer to seal top and bottom against the tank and tightened the whole assembly.
but yes i definitely need a stand alone.
