dry NOS nozzle placement
Hey nitrous guys - newb here. I have spent hours searching this forum, so I understand the nozzle basics - 3 to 4 inches in front of the MAF and point them near the sensor. The problem is that I did an LS1 swap into a Miata and had to change the entire intake routing because of low clearance under the hood. Now I am installing the dry NOS kit with dual nozzles and need some advice. In this intake arrangement where would you suggest putting the spray nozzles?
I could never get a good nozzle location, and after swiss-cheesing my intake, I swapped to the HSW Interface and used a plate. If you want to spend some extra money, it is an easy way to get a guaranteed correct setup.
Nick
