Wiring Diagram
Old Jun 29, 2009 | 11:13 AM
505OUTLAWZWS6's Avatar
Default Wiring Diagram
I know i can piece a few diagrams together for my setup, but just trying to see if anyone has a diagram of my setup; I have the cold fusion kit with msd window switch 8969, purge kit, and wot switch. Should i get a fpss if i just put in a new walbro 255?
Old Jun 29, 2009 | 04:14 PM
Chris@NitroDaves
Guest
Posts: n/a
Personally and Professionally i'd suggest getting a FPSS. $50 to potentially save a motor is money well spent IMO
-Chris
Old Jun 29, 2009 | 07:24 PM
Thanks man, you guys are awesome!
Old Jul 16, 2009 | 06:33 AM
Can someone tell me the proper places in this diagram to put inline fuses?
Old Jul 16, 2009 | 06:42 AM
jmill96Z's Avatar
From the relay (the 30 pin) to the battery is where your fuse will go. Also, I would run the purge off of an additional relay. Makes the draw less on on the stock acc. wiring this diagram has you tapping into.
Old Jul 16, 2009 | 06:47 AM
Are there any diagrams that show it wired into a seperate relay? Doesnt need to match my exact diagram just showing the purge on its own...
Old Jul 16, 2009 | 06:50 AM
jmill96Z's Avatar
I'll dig mine up
Old Jul 16, 2009 | 06:52 AM
jmill96Z's Avatar
Not as fancy as above, but hey, it works
Old Jul 16, 2009 | 06:57 AM
The picture doesnt work for me
Old Jul 16, 2009 | 06:58 AM
jmill96Z's Avatar
Me either. I thought it was a gov computer issue. I'll fix it when I get home
OK, basically you send one wire from the noid to ground, and the other to the 87 pin of the relay.
30 pin goes to the battery
85 goes to ground
86 goes to switch
other side of switch goes to keyed 12 volt
Old Jul 16, 2009 | 07:37 PM
One more quick question i have a 60 amp relay and a 30 amp relay, which one should i use where. 60 amp on solenoids and 30 amp on the purge? Thanks again for any help
Old Jul 16, 2009 | 09:11 PM
jmill96Z's Avatar
That will be fine. The purge probably only draws 8-12 amps
