Can I mount my dry fogger right before the MAF?
Old 11-15-2003, 12:00 PM
Mooobunnny's Avatar
Default Can I mount my dry fogger right before the MAF?
Can I mount my dry fogger right before the MAF? Or is that too close?
Thanks, Chris
Old 11-15-2003, 12:44 PM
ROB'S SS's Avatar
id say as long as the nitrous is passing through the maf, it would be ok
Old 11-15-2003, 07:56 PM
slow's Avatar
no, you want it a few inches infront so it has a chance to dissipate, to give a reading.
Most mount them on the airlid, facing forward, so it is not a direct hit into the maf.
Ryan
Old 11-15-2003, 08:57 PM
Chicago Z06's Avatar
Do not spray directly into the MAF.. this may cause it to potentialy fail due to 900+ PSI spraying into the resistors on the heating element. the proper way is to have opposing nozzles spray towards each other in the air box which will not affect the MAF...
