Nitrous bottle lose pressure over time
I filled up my bottle probably about 2 months ago... the pressure has been very consistent up until this past week. I have not opened the bottle yet. I added some fittings for nano before this fill. I'm wondering if the fittings didnt seal and caused a slow leak or if its just normal for the pressure to drop after such a long time?
Normally the bottle would be over 600psi in my closet (temp in house hasn't changed), the other day i noted about 550 then a day later 500 and now its around 440.
Thanks
Thanks
I have a newer bottle and have experienced the same thing over the past couple of months.. I have not changed any fittings on it and have sprayed the bottle down with soapy water and can't find any leaks to justify the lose of weight or pressure over the past couple months..
Thanks
Thanks
Buy a scale, harbor freight sells shipping scales for cheap and are nice to have. Get some soapy water and spray your fittings, find leak and fix.
