What size shot are you running on your stock bottom end?
#47
stock ls6 block with bad *** ported heads that flow awesome!!! ll , big ms3 cam... and all supporting mods. 40lb injectors been spraying175 for over a 1 year with 26,000 miles. probably gonna step up to a tnt f2 200 shot through a power ring
nic d tuned!!!!
nic d tuned!!!!
#48
hy-Brid dry before the MAF style. i was of the few that had great success with a before the MAF style kit. I now run a after the MAF style dry and 3-stges. All the info on the original kit can be found in old posts as I covered all steps in power upto the 285 and described everything in detail.
Robert
Robert
#49
I run a 140 rwhp wet shot on an all stock motor LT1. I run tr6's gapped at .035 and have a little timing pulled out of the tune. Ive run 6 or 7 bottles so far with no problems! I have 70,000 miles.
#54
150 wet shot setup to kick in at 6500 rpm through a window switch!
How many people spray off the line on their stock 10 bolt? I've been tempted to do so!
#56
Bought my T/A new in 1999. bolted up the spray the first week I had it. 10 years later, 100+ bottle later, many broken drivetrain parts later - damn 6 speed, the stock bottom end is still going strong. Just dyno'd 599 hp, 724lbs torque on a 150 shot. I have blown a few head gaskets, had a ugly nitrous backfire (fuel issue), but never hurt the motor.
#57
Guest
Posts: n/a
Back in 2000 when i first picked the car up and didn't have the knowlege/ nor nitrous know how that i have today.
200hp TNT kit TR6's gaped @ 35
No tune, no fuel pump, no safety items nor window switch, and 93 octane
I'm talking showroom stock ( Drive it from the dealership and put a 200hot on it ) and once i put the kit on there i sprayed on everyone and everywhere i must have went through 3-4 bottles a week for about 6months before it blew.
Present Day
Stock shortblock LS6 Motor ( Around 15-20thou miles on it )
200hp via Spray bars plumbed into a Vic Jr
BR7EFS plugs gapped @ 33
Battery relocate Dedicated w/ C16
Mix of 93 and 110 in the factory tank
Present Day
