Bottle Pressure Explained...
Old Jul 21, 2009 | 12:08 AM
jetblast's Avatar
Originally Posted by Brad@NANO Direct
Most companys have a recommended pressure of where there particular system works well at. Some solenoids cannot handle above 1000psi. Although most of the time when a solenoid does not open it is usually a ground or wiring issue. Personal preference is usually what calls out for the pressure.
When i jet customer cars i have had customers start out with there standard system before NANO anywhere from 850psi to 1150psi. Like i said ask your nitrous manufacture for there recommended pressure or find where you like best. With NANO our starting pressure is always 1050psi and 950psi flowing down track.
interesting thing that happened 3wks. ago. the speed shop at the track, serviced the bottle 3lbs over the limit and so with my nano connected [press. normally at 1050] the bottle press. misteriously settled to 900, i swear my purge cloud seemed much thicker, and it certainly left me curious to see if 900 is a better, much denser shot, hence the run felt surprisingly strong. the press. did stabilized back to 1050 after the third run, thought i bring this up since we are discussing bottle press. dynamics. i didn't think that bottle press. droped at all when on nano. i've had my wife activate the purge sys. and i counted to 12, while watching for press. drop, and did not see more than 50psi drop. i have also purged with the nano bottle not connected but with the n2o bottle already primed to 1050 and noticed almost the same small drop.
Old Jul 21, 2009 | 12:56 AM
383LQ4SS's Avatar
Originally Posted by Beaflag VonRathburg
There was a good discussion about this a long time ago. One guy was talking about how he ran 1400 or so psi, made higher average power, and discussion ensued. I think one of the advantages of the nano setup is having consistent pressure without heating the bottle. You are getting a constant pressure while flowing a higher density nitrous through a static line.
I'll see if I can find that other thread.
https://ls1tech.com/forums/nitrous-o...cussion-2.html
that was a good thread!
Old Jul 21, 2009 | 08:04 AM
Brad@NANO Direct's Avatar
Give me a call today, we can discuss it. There will be a 100psi drop from 1050psi to 950psi when the solenoids are activated.
785-331-2390
Brad
Old Jul 21, 2009 | 08:17 AM
Mike@HSW's Avatar
Originally Posted by JAX04
/this is a great write up, so, does this mean i should wrap my nitrous line in the engine bay with heat wrap? cuz ill do it!! lol!!
this was a great read up, one more reason to couple my harris/nx system with a nano bottle. thanks man.
sticky?
lol not necessary, i promise...it was more to illustrate what goes in to properly designing a direct port system.
Old Jul 21, 2009 | 08:38 AM
Mike@HSW's Avatar
i would think that maintaining the bottle press. with a nano sys. becomes more benefical than a bottle heater, but what is the ideal press.? 900? 950? or 1050? ect. fact, my supply line runs the entire length of the car [ trunk to eng.] and so i purge for what seems a very long time compared to some videos i have seen. does a 15lb bottle hit a bit harder than a 10lb bottle?
depends on your shot size. We jet out systems for 950, ideal is whatever works best for your system. But yes we do believe ideal in general is right around there.
Old Jul 22, 2009 | 09:03 AM
Mike@HSW's Avatar
Originally Posted by 383LQ4SS
I was looking for that but couldn't find it. That was a great thread.
Old Jul 22, 2009 | 11:24 AM
rrmccabe's Avatar
Is there supposed to be something that comes with your systems that states this?
If so I missed it.
Old Aug 4, 2009 | 05:51 PM
Robert56's Avatar
so if you jet for 900psi and your goal is 150hp, then the jet size would have to be smaller compared to 1050psi. and if a kit is designed for 1050psi and you run 900psi will you be running more hp? and if true then 150jet set-up would would be maybe 170? is this right? so what's the ideal psi?
When I was running the dry hits before the MAF, rather than change jets I would manually use my heater(s) to increase HP. So yes the relative same jet size will in fact become different hp setting per what PSI is run. that is one of the reasons we need to stick with jetting suggested by the manufacture for their chosen PSI.
I think the consensus is that 950PSI flowing pressure is the ideal PSI, given a free flowing system. NANO, NOS and HSW, IIRC, are but a few that run this PSI.
My opinion today is that bottle heaters are dated technology and any real serious nitrous user would benefit by running a NANO system. That has always been one of the biggest draw backs of running nitrous, esp bigger hits, that is the tune falling off on the top end and loosing power. Some classes allow only one kit and if we can stabilize the pressure that is good for about a 25% increase in power thru the run. Also we can run the entire contents of the bottle which allows a smaller bottle (weight) for class racers.
Robert
Old Aug 5, 2009 | 09:00 PM
SHovV's Avatar
good write up man, thanks
Old Aug 5, 2009 | 11:03 PM
GT Griller's Avatar
so if you jet for 900psi and your goal is 150hp, then the jet size would have to be smaller compared to 1050psi. and if a kit is designed for 1050psi and you run 900psi will you be running more hp? and if true then 150jet set-up would woul be maybe 170? is this right? so what's the ideal psi?
Isnt that backwards?...I mean ur now runin less pressure thus less nitrous thru the same jet for a 1050 rated kit..wouldnt mean less hp?
Old Aug 6, 2009 | 12:15 AM
SkullV's Avatar
So my questions is:
"If I am running a 125 shot on an HSW kit should I set my bottle to 950 or set it to 1050 in anticipation of a pressure drop?"
Old Aug 6, 2009 | 12:22 AM
  #32
jmill96Z's Avatar
950 psi
Old Aug 6, 2009 | 08:27 AM
  #33
Mike@HSW's Avatar
Originally Posted by SkullV
So my questions is:
950, thats what our kits are jetted for. The point of the post is that a pressure drop is going to be smaller at 950 than 1050. Now dont get me wrong on a 125 shot it might not be noticable at all on a smaller shot.
Old Aug 8, 2009 | 03:10 PM
  #34
brokenfly's Avatar
could the gaseous state above 1069 psi be used to soften the hit a little???
Old Aug 8, 2009 | 03:14 PM
  #35
jmill96Z's Avatar
Don't get any ideas LOL
Gas form isn't what you want to be spraying. It's really not even a pure gas at that temp. Not an ideal situation. If you want to soften the hit, increast the line length from the solenoid to the nozzle.
Old Aug 8, 2009 | 03:16 PM
  #36
brokenfly's Avatar
ideas is all i got sometimes...lol...
Old Aug 10, 2009 | 03:46 AM
  #37
Robert56's Avatar
So my questions is:
Sure you can do that, but one end of the spectrum the tune is going to be off. NANO is finally the cure to all bottle pressure drop issues which lead to top end power lose and tunes that don'e stay relative. Also cures the temp based low bottle pressure issue and subsquent skewed tunes. Mike correct me if I am wrong, static bottle for your kits is 1050psi and dynamic is 950psi?
Robert
