Sticky? For NANO Refill stations???
whats the going rate for Nitrogen?
Thanks in advance.
Thanks for all replies.
The NANO system can be filled with HPA (high pressure air) or HPN (high pressure nitrogen).
When filling them at home you will get a 5,000psi or 6,000psi nitrogen bottle from your local welding shop such as Praxair, Linweld, or American Airworks. It costs around $7-10 a month to rent. Then you will call me for a trans fill line kit. Its around $150 to $175 depending on what cga fitting you need. Then you can fill from your garage and when you need a new bottle they will come and drop you off a new one.
