purge
Old Jul 28, 2009 | 12:30 PM
Chris'stransam's Avatar
Default purge
what size purge line should i use ? Bronze or steel.
Old Jul 28, 2009 | 12:33 PM
ttranssam's Avatar
? -4an
Old Jul 28, 2009 | 01:11 PM
Chris@NitroDaves
Guest
Posts: n/a
3/16th brake line can work as the purge.
-Chris
Old Jul 28, 2009 | 06:57 PM
xXxSilveradoxXx's Avatar
-Chris
If I was to make a setup to purge out of two separate places would I go from a single 3/16 to two lines that are smaller or just keep the whole thing 3/16?
Old Jul 28, 2009 | 07:03 PM
Mike@HSW's Avatar
you can leave it at 3/16". we actually sell a kit that does this
http://www.harrisspeedworks.com/prod...5&cat=6&page=1
we also carry 3/16'' flexible aluminum line if thats what the OP is looking for
Old Jul 29, 2009 | 02:20 PM
Chris@NitroDaves
Guest
Posts: n/a
In order to do it with the 3/16th line you will need a 1/8th by 3/16th compression T and however much line it will take to exit where you wanted.
We offer two different kits that would let you have the dual outlet purge.
Windshield
http://www.nitrousoutlet.com/catalog...roduct_id=2757
or
Hood Exit
http://www.nitrousoutlet.com/catalog...roduct_id=2758
-Chris
