how to Gap the plugs ?
Old Aug 4, 2009 | 12:28 PM
ShiznityZ28's Avatar
I use hammers to close the gap and vise grips to open them.....
Old Aug 4, 2009 | 01:26 PM
Maybe you should just cut the sraps off the tr-6's now the spark will jump from the barrel to the electrode. it will save time so you don't have to saw them off going down the track on a 250 SHOT.
Old Aug 4, 2009 | 01:38 PM
ATVracr's Avatar
LOL
Old Aug 4, 2009 | 01:57 PM
PONTIAC SLP's Avatar
Originally Posted by Mike@HSW
Whats done to your motor if anything? stock compression? shot size alone does not determine plug choice. assuming stock compression id just run an 8, 7 might be ok, but there's no reason not to run an 8 either.
LS1 5.7 , 10:00 CR
Eagle Rods 6.125 , Diamond 3.905 -2cc , STD Crank
STD 241 heads , MS4 112LSA , 7.400 pushrods
Walbro 255 fuel pump
TNT F2 250HP
4.10gears
Powerbond underdrive pulley
the car pulled 630RWHP with TR6 plugs.
Old Aug 4, 2009 | 02:18 PM
ATVracr's Avatar
Originally Posted by PONTIAC SLP
LS1 5.7 , 10:00 CR
TNT F2 250HP
4.10gears
Rich as hell I bet.... should make close to 700 with a 250 TNT hit.
Put a TR9 in it and lean it out and watch it pick up power.
Old Aug 4, 2009 | 03:10 PM
700 ? I bet you're good in math lol 380+250= ???
Old Aug 4, 2009 | 03:20 PM
ATVracr's Avatar
Its a fukin TERD if it only makes 380 on motor.
Besides that the tune cant be great if it lives on TR6's and a 250shot.
What does it run on the 250? or have you only dynoed it? We can make anything live on the dyno for a 2-3 second pull.
