The Nitrous Outlet 98-02 F-body Nitrous System
#61
Introducing The Nitrous OUtlet 98-02 F-body Specific Nitrous System.
After many hours of product design and prototyping we have designed the Nitrous System of the future. The Nitrous Outlet 98-02 F-body Nitrous system is the safest, best fitting, and most tuner friendly system on the market. From newly designed solenoids to prefabricated stainless hard lines there is no other nitrous system on the market that can offer the same sexy look and reliable horse power.
Unlike other brand nitrous systems on the market the Nitrous Outlet system is truly a system designed to fit your application. Other companies use universal solenoid brackets and have sloppy looking braided hoses lying all over the top of the engine. The Nitrous Outlet system comes with application specific hardware so that you will not have to order special fittings or different length hoses for a custom looking install. In return you get the best fitment with out the universal sloppy look.
Our 98-02 F-body System includes the following Features.
1. Newly designed high flowing solenoids built to work with today’s fuels.
2. The highest flowing, best atomizing and best fitting Nitrous Plate available!
3. Custom designed solenoid mounts.
4. Prefabricated Stainless Hard lines.
5. Precise fitment fittings.
6. CNC machined fuel feed with Prefabricated Hard line.
7. Bolts on using all factory equipment. (Including cold air box)
8. Wide range of accessories to work in conjunction with our nitrous system.
9. Capable of supporting Horse power levels up to 400 HP!
We are currently taking pre orders and will be able to ship as early as the first week of August. (Next week)
Sale is good for the month of August. Expires 08-31-09
You can place your order by calling 1-866-648-7637 or 254-848-4300
Special introductory price is 575.00
Thank you for your support.
Nitro Dave
Note: These pictures are from Mock up. Finished products will be anodized. Installed pictures will be posted later.
Dont forget to check out our full line of accessories!
Dave
Nitro Dave
Dave
#67
Guys got my kit yesterday and it looks amazing. Will be awhile before I get it installed and all the accessories I need. This is my first nitrous kit, never been a fan of it due to the messes I've seen people with. As soon as I saw this kit I called Dave immediately.
#76
Yes sir.. Already done..
Check this link out..
https://ls1tech.com/forums/nitrous-o...ic-system.html
#77
What is the cost to change the plate size? I'm very interested in one of these kits.
Also will the brackets work with aftermarket fuel rails? (sorry if that was asked already and I missed it.)
#79
I'm probably going to need to upgrade them, although with a wet kit it may not be necessary...
#80
This system will work with all fuel rails. The solenoid brackets bolt to the intake bolts and not the fuel rail bolts.
Dave
