plug question for 150-200 hit
Old Aug 4, 2009 | 12:16 PM
spaulding's Avatar
Default plug question for 150-200 hit
im running a stock cube ls1 with a 240/242 cam 595/598 lift on a 112+2 and ls6 intake and untouched stock heads,arp rod bolts what plug and heat range/gap should i be running to be able to throw 150-200 shot on it car is basicly a drag only setup ewp,manual rack all the light weight stuff and a th 400 w/ abrake and 3:73 9 inch and in the neighborhood of 3200lbs figured id give as much info as possible the car has tr6's in it now but dont want to run those on the hose
