Introducing The Nitrous Outlet LT1 Specific System
Old Aug 5, 2009 | 12:36 PM
djjab57's Avatar
Im new to N2o so what if you have more than 400 HP ?
Old Aug 5, 2009 | 12:52 PM
buzz12586's Avatar
It means you can spray up to 400 extra horsepower on top of what you already have.
Old Aug 5, 2009 | 12:55 PM
BizZzatch350's Avatar
Moderator
Looks good, did you guys ever figure out that bracket for the 93 autos?
Old Aug 5, 2009 | 01:07 PM
djjab57's Avatar
Thank you I will be ordering mine then
Old Aug 5, 2009 | 01:25 PM
Demon 383's Avatar
Very nice! I can see a polished intake manifold and monoblade to go with that kit. That would look badass.
Old Aug 5, 2009 | 01:39 PM
Chris@NitroDaves
Guest
Posts: n/a
Originally Posted by n2ocamaro
How about some color choices for the plate and solenoid bracket.....like blue
We can have the plate stripped and anodized for you if you'd like.
Originally Posted by camar0corey
Any kind of deal on the solenoid bracket and hard lines? I bought a plate kit already, well almost two years ago now I think. Wish I could get around to installing it.
the bracket is $36.75 and the hardline will be around $20
Originally Posted by Formula96
^^^ Same boat, in december i purchased your plate conversion for the 52MM throttle body, how much for just the new solinoids, mounting plate, and stainless lines?
the bracket is $36.75 and the hardline will be around $20 and the New fuel noid is $84.95
Originally Posted by want297z
What size is the opening in the plate? 58 or larger? What about for a mono blade plate?
We offer the plate in 52, 58, and Mono
If you havent upgraded the fuel pump you would need to in order to spray the car. If the motor is stock also then the max i'd spray on it would be 150hp.
What tyoe of bracket are you refering too??
-Chris
Old Aug 5, 2009 | 02:29 PM
Formula96's Avatar
so $250 for what i need (i added new N2O noid too)
Old Aug 5, 2009 | 02:35 PM
Chris@NitroDaves
Guest
Posts: n/a
Yes sir
Old Aug 5, 2009 | 02:44 PM
djjab57's Avatar
-Chris
Im in the middle of building a 355 with 6 inch I beam scat rods and forged Mahl pistons stock crank and LE2 heads
Old Aug 5, 2009 | 03:58 PM
DopdBrd's Avatar
So does that 599.00 include everything? Like bottle and feed line? How much would it be for the kit minus the bottle, upgraded -6AN feed line, and a purge?
Old Aug 5, 2009 | 04:39 PM
Chris@NitroDaves
Guest
Posts: n/a
It includes the bottle, lines and everything needed to install the system. Purge will be $99, 6an main feed is $82, and taking the bottle out will discount the kit by $60.
-Chris
Old Aug 5, 2009 | 10:30 PM
  #32
camar0corey's Avatar
Sounds good on the lines and bracket.
Can you describe what is different about the fuel solenoid? Is it something to worry about if I have the older one?
Old Aug 5, 2009 | 10:40 PM
  #33
Nyte96's Avatar
Kyle had the 1st..I had the 2nd But the 1st with braided instead of hardlines.......I think haha, Yeah the NOS solenoid is just threre for "mock-up" I now have a Brand X in its place so all of them match with the exeption of the ICEMAN NX one..but..cosmetically the same as the othe rones now
Camara phone pics
Old Aug 5, 2009 | 11:52 PM
  #34
great421's Avatar
Default Yeah - Exactly!
Damn you Nitrous Outlet. I am trying to save money,
2X Vote!
I just finished instaling my STS, and now you entice me with this!?!
You must just WANT me to break my 5th 10 bolt!
(I want one! )
Old Aug 6, 2009 | 07:20 AM
  #35
n2ocamaro's Avatar
I will be going this route as well since I need new noids.
Old Aug 6, 2009 | 07:42 AM
  #36
n2ocamaro's Avatar
Oops, forgot about the plate. I might as well get the whole kit. I see a 2nd stage in my future.
Old Aug 6, 2009 | 09:48 AM
  #37
94Z28rag's Avatar
What about us guys with a stock motor (CAI, catback, tune)? How will the plate work with our 48mm TB?
Old Aug 6, 2009 | 10:54 AM
  #38
want297z's Avatar
There should be no problem as the holes in the intake or 52mm.
To order do you need to call or can it be ordered online?
Old Aug 6, 2009 | 03:12 PM
  #39
casper383's Avatar
Kit looks sick Dave, nice work as always!!
Old Aug 6, 2009 | 04:43 PM
  #40
Chris@NitroDaves
Guest
Posts: n/a
You will have to call to order..
There is nothing wrong with the old noids. The new ones are bottom exit and the piston material has been upgraded as well.
-Chris
