flycutting with nitrous?
Old Aug 8, 2009 | 03:20 PM
z28adiction's Avatar
Default flycutting with nitrous?
My friend and i just got done installing a vindicator in my car and took out 91 thousands out of the intake and exhasut which i know is alot. Would selling the nitrous kit i have for the car be a good idea lol. i really am afraid of the pistons being to weak and burniung through. I have a potential buyer also.
Old Aug 8, 2009 | 11:50 PM
ShiznityZ28's Avatar
Had 90 thou out of my cousins car. sprayed 250 at it for an entire year and had 120K miles. but eventually burned the #8 intake pocket
Old Aug 9, 2009 | 01:02 AM
Z-RATED94's Avatar
Did you smooth out the cuts in the pistons when you where done?
Old Aug 9, 2009 | 09:26 AM
yes used a dremil and a sanding drum and knocked all the edges off.
Old Aug 9, 2009 | 10:32 AM
THENASCAR's Avatar
that ones kinda up in the air, you may or may not have problems, i would be worried about thinning out the piston that much because i beleive you only have like .165 to work with. dont quote that, that number just popped in my head. you could probably run it for a while but not on a big shot or you engine will most likely not hold. but with a proper tune. whoknows right?
Old Aug 10, 2009 | 09:28 AM
Nick@HSW's Avatar
We sprayed Matt's black T/A for a long time on some deep flycuts. We never had one issue with it. Just make sure you knock all the edges down to prevent any hot spots.
Nick
