150shot dry timing question
Im planning on using a nitrousoutlet halo where the air filter is. Will i need to pull timing for this shot or will the maf pull timing and add fuel?
You can pull timing via spraying the MAf and it works great. it will not effect your n/a tune at all. You need no aftermarket timing pull box, it's free. You do have to have access to, or own a tuner program to set it up. But you can have it done by your tuner if you don't own a tuner program. My full write-up how-to can be found on google, or at my site should you know what that is.
Robert
Robert
