running a Big dry hit?
-6 feed 2 10# bottles, NX pro solenoid(s)
42# injectors, intank pump, C-12, Tr8's gapped .032-.038 timing dropped waay down.
im intriuged as to if there would be any reason why i can just work my way up to 300+ ? i've got all kinds of jets (in pairs
) 18-85 access to a wideband, and a dyno now. anyone else doing this? spraying before the maf and having it add in the extra fuel? what tables if any should i be modifying in the ECM? perhaps setting up the maf to tell the motor to go super rich by a certian gms/cyl load? anyone done this?it'd be absolutely pimp to be able to do this and still run well n/a..
be careful of reaching the maximum maf frequency, and running lean.
other than that, you should be fine, but i don't think the stock maf will register 300 worth of n20 on top of a healthy ls1.
Ryan
Jeffrey
i talked frequently with al, (383lq4ss) about this stuff, but all he kept mentioning was "custom tuning" well, im my own tuner, and that dosent really break down the details as much as i needed.
He did the MAF setup...he also made it so its 28 degrees timing on motor and 20-22 degrees when the juice comes on. No changing programs. Its actually fairly easy...but you need to do some datalogging to plot your nitrous timing Map a certain "gap" from your all motor timing map.
You could also do a two stage wet/dry and still get the same benifits as long as you spray the dry first.
yep, thats about it
and, no you run around just like you normally would n/a. not rich all the time, that'd be imprectical for those of us that drive the heck out of our cars. (like me) it only goes super rich when you hit the button. the maf registers it, kicks down the timing, and adds in the extra fuel. pretty slick. im just wondering now how big a shot i can run on pump gas alone.
i think i'll just talk kyle into buying efi live for us all
, and i am gonna
you vents when i get down there.
. learn how to tune a n/a engine first, then worry about sprayin'
My 383 only dynoes in the 42x range when setup for juice. The last dyno netted 707rwhp. So thats roughly 280-290 range actual.
Tag...Im using the nozzles that came with the 5177 kit..still has one on either side of my Wiser lid. Just that now one saide sprays 130-140 and the other side sprays 130-140.
Asian...Nitrous flowing down the intake will flow darn near perfectly even, or atleast nearly as even as the air would. Its the fuel you have to worry about since its much denser. Using the MAf to tune for the dry shot can give you alot of fine control as well. But yes...I keep Af around 11.5-11.9 to 1. I also retard plenty of timing and run 100 octane unleaded. All those combined will keep you safe if you have one cylinder a percent or two leaner than the rest. Basically tune for the leanest cylinder. Read plugs, check knocks, and use wideband on a dyno.
And yes it feels great when you slam the full shot on it. We predominatly race from a roll over a long bridge here in Tampa. Usually from 40-150. I havent been beat with this new setup yet. I have raced 800 rwhp single Turbo Supras, ROE supercharged Vipers (the notorious Miami Viper), and plenty of other cars. All have fallen
I am currently changing a few things to make the first stage a 200 dry and second stage 200 wet. Or possibly 3 stages. 200 dry/ 100 wet/ 100 wet at 3000/4500/5500 rpm respectively. Spin to 6800 rpm total.
A few pics of my "simple" setup
two stage
nitrogen push
