Sprayed for the 1st time!!!
and yes, they would.. i have adjustables.. worth the money.. you should be able to hook though if you just lower air pressure.. try that and see how you do next week first.. then go from there.
take your filter out.. let your car cool for a good hour before you run it the first time.. minimum 30 minutes in between runs.. i put a bag of ice on top of my TB and intake, dont know how much it helps in cooling but i think it does!
every little bit helps!
also, I got a bud bringing his camera, so I post up some vids for you.
also she does love the nitrous as do I, I went through 3 bottles since sunday
Car is a beast on the streets, and mean from some high rolls, but rolls are
either way, From going from a stock time from 8.68 to a 7.43, it was a blast. It was the most fun I have ever had in my car!
also, I think im going to pull the front sway bar, and see if that helps. looks like a lot of guys do it and see some improvements from it.
yeah, I am going to try it, also I have hotchkis lca's.
