M6 guys, who are spraying!!
Old Aug 18, 2009 | 07:31 AM
racejunky02's Avatar
Default M6 guys, who are spraying!!
Trying to do some homework on nitrous and what I can expect, please help..
Tire size?
N/A times vs Spray times?
60ft?
How much spray?
Wet or Dry?
Are you spraying off the line?
What gears you have in the rear?
Old Aug 18, 2009 | 11:11 PM
Soul Crusher's Avatar
Stock tires that suck
12.9@118 with infinite wheelspin / 13.4@107 N/A
2.4ish on spray / 2.2 N/A
100 shot
wet
yes
stock 3.42
Old Aug 18, 2009 | 11:20 PM
killaxtranz's Avatar
nitto 555r 315's
havnt ran it at the track yet
broken rear end cuz spraying off line on street lol
175 shot
wet
stock 3.42
make sure if u gotta lot of tire u dont spray off line or u minus well just video tape it and let us all watch u blow it. and also stock clutchs hate nitrous upgrade to monster or spec
ls2 bait's Avatar
Tire size? 28x10.5-15 et drag
N/A times vs Spray times? 10.78@128 vs 9.91@141 (thus far. only 2 attempts)
60ft? 1.57 motor, 1.44 n2o
How much spray? 200 shot
Wet or Dry? wet
Are you spraying off the line? about 5-10 ft out
What gears you have in the rear? 4.10. about to switch to a 3.73
Old Aug 19, 2009 | 08:02 AM
Thanks guys, this helps..
Old Aug 19, 2009 | 08:16 AM
Gordon0652's Avatar
Wet or Dry? wet
Why to the 3.73s? Been impressed with your build! Going to do almost the same with my driveline!
Sorry for the
Old Aug 19, 2009 | 08:41 AM
not a problem, having that question answered could help me too...I've never used nitrous so any info is appreciated
Old Aug 19, 2009 | 10:26 AM
purdueranger's Avatar
Tire size?
28x10.50 ET Drags
high 11s vs 10.7x
60ft?
1.4x to 1.500
How much spray?
150 shot on a nitrous dave wet plate kit
Wet or Dry?
wet
hell yeah
4.30 gears
I was still trying to dial in the suspension but the car hit the wall before I could finish it. I am sure she had a low 10 second pass in her with tweeking the launch and dial in the shocks along with some killer air. Hot Mid West air in the summer sucks. All the times were from 2 weeks ago in Springfield, MO where I went to the track to race. My summer times now are what the car was running when it was cold outside with stock heads.
Old Aug 19, 2009 | 11:55 AM
So you didn't wait even a little bit after you took off, you sprayed right from the get go...
Old Aug 19, 2009 | 12:13 PM
ls2 bait's Avatar
Sorry for the
trying to make the car more useable on the street as i drive it atleast 4 days a week usually and i go to the track 2-3 times a year. as it sits now i cant use the nitrous at all on the street without taking up 2 lanes and it spins the tires thru the first 2 1/2 gears on the motor.
Old Aug 19, 2009 | 12:19 PM
00silverGTP's Avatar
Tire size? stock rims with mickey drs
N/A times vs Spray times? 12.8 na 12.2 100shot
60ft? 2.0 on both
How much spray? 100 HSW Plate
Wet or Dry? wet
Are you spraying off the line? set on wot, but I slip the clutch off line to save 10bolt. hence the 2.0 60'
What gears you have in the rear? 342
Old Aug 19, 2009 | 02:16 PM
Right off the line. I let the clutch out and floor it at the same time. it makes for one hell of a ride down the track.
Old Aug 19, 2009 | 07:21 PM
Gordon0652's Avatar
To add to this : My Plan.
Currently building a 440 LS7.
-28" tire, slick
-Expect a low to mid 10 N/A and very low 9 on the bottle, maybe better.
-150-225 shot
-wet, direct port, standalone with race fuel in the standalone tank
-6-speed, 4.11s
-Most likely spray out of the hole.
Something very similar to ls2 bait setup...
EDIT: i will be at full weight also.
