Quick Nitrous Wiring Question
Old Aug 20, 2009 | 11:14 PM
xXxSilveradoxXx's Avatar
Default Quick Nitrous Wiring Question
Does anybody see a problem wiring a Bottle Heater, Bottle Opener and a MicroEdge to the same arming switch?
Old Aug 20, 2009 | 11:22 PM
nprather's Avatar
on seperate relays for all three....no.
I wouldnt but that doesnt mean you cant
Old Aug 20, 2009 | 11:40 PM
Yeah, separate relays for all three. The reason I ask is this is my first N2O car and to me one switch would be very convenient and clean. I'm just not sure if that is a good idea though.
Old Aug 21, 2009 | 12:59 AM
Gary Z's Avatar
You need separate switches for arming your system and heating the bottle. The bottle heater is very slow. It may be necessary to heat the bottle when the engine is not running. It would be extremely unsafe to not have a separate arming switch. You are probably thinking of a single electrical power switch, which is certainly ok.
Old Aug 21, 2009 | 01:17 AM
I'm talking flip one switch and the MicroEdge powers up, the bottle opens, and the heater turns on and regulates the pressure in the bottle.
Old Aug 21, 2009 | 02:02 AM
Gary Z's Avatar
This is not a good plan. The MicroEdge should be on whenever the ignition switch is on. You need to be able to configure the MicroEdge and use its display independent of the bottle. In my opinion it would be poor practice to not have separate switches for the heater and bottle opener.
Old Aug 21, 2009 | 02:08 AM
Very good, that's how I'll do it! Thanks for the advice!
Old Aug 21, 2009 | 09:09 AM
Nick@HSW's Avatar
The bottle opener will require using a DPDT type switch. Sort of like the same switch you use to open and close your window. So that can't be attached to a on off rocker switch unless using a control device to open and close it. I would also keep the heater and arm switch separate so that you can use one while not using the other. Hopefully that helps?
Nick
