Anybody make a "long" nozzle?
Old Aug 26, 2009 | 04:03 PM
gillbot's Avatar
Default Anybody make a "long" nozzle?
The transition pipe from my MAF to throttle body thick and larger in diameter than the stock piece. The NOS wet nozzle I have isn't long enough to spray "into" the throttle body. Is there a longer nozzle? I really don't want to drop the funds on a plate.
Old Aug 26, 2009 | 08:35 PM
Nick@HSW's Avatar
Our black mamba nozzle is slightly longer than the traditional nos nozzles. It also features a 70* exit angle to help spray across the face of the throttle body. You would also need the 1/8NPT nozzle retaining nut. Let me know if you have any questions.
Nick
Old Aug 27, 2009 | 10:59 AM
Chris@NitroDaves
Guest
Posts: n/a
We offer a 1/8th nozzle that will suite your needs to a T.
1-8th Nozzle
http://www.nitrousoutlet.com/catalog...roduct_id=2528
Nozzle Adapter
http://www.nitrousoutlet.com/catalog...roduct_id=2719
-Chris
Old Aug 27, 2009 | 12:39 PM
gillbot's Avatar
How close does it need to be, my current nozzle is probably just over 1" too short.
Old Aug 27, 2009 | 01:15 PM
Nitro Dave's Nitrous Outlet's Avatar
The key is to make sure the nozzle tip is sticking through far enough that the Bath tub (Discharge area) is not obstructed.
Dave
Old Aug 27, 2009 | 01:26 PM
gillbot's Avatar
my current nozzle can make it into the air stream, but i believe it's a 90 deg nozzle so it would currently spray the edge of the tb and not towards the center.
