Uncorfortable with nitrous tune
Typically naturally aspirated motors make the most power at around 12.9:1-13.1:1.... some nitrous motors make max power at the same air fuel ratios but it is not for the faint of heart and certainly not amateurs... running a nitrous motor that lean can either make max power or make 8 aluminum ashtrays...
but to be safe i'd run TR7 plugs, take some timing out of it initially and shoot for the aforementioned 11.5:1.... with c16 and that amount of spray it would be tough to hurt something... and yes 17# in a 10 lb bottle is VERY empty. probably all kinds of pressure spikes causing the wavy graph... rich and lean swings... just ugly pulls....
25 lbs in a 10 lb bottle is full.... We typically make two passes on a 15 lb bottle and then stop using it.... I burn maybe like 3lbs of nitrous per pass (325 shot w/purge on the starting line).... So once my bottle gets to 9 lbs it's in need of a refill... ON a 10 lb bottle and a 125 shot i'd say 3 passes max and consider it empty.
