Direct port set up.... pics inside
Old Sep 1, 2009 | 06:26 PM
stonemonk's Avatar
Default Direct port set up.... pics inside
Well here's my setup, its a nx direct port jetted for a 200 shot. I also have a zex kit just incase..... The 2nd kit will not be used as the racetronix pump wont support both kits, that will be for when i have a stand alone. Still have a few issues as of now, need to run a second purge line, my nitrous solenoid has a SLOW leak, the fuel fitting and line on the zex kit are not correct and obviously I need a stand alone. I also want to find a way to put the fuel solenoid closer to the block...... LMK what ya think.
Old Sep 1, 2009 | 07:34 PM
1badA3Z's Avatar
Looks killer man,nice setup!!!
Old Sep 1, 2009 | 09:48 PM
Brad@NANO Direct's Avatar
Looks good
Old Sep 1, 2009 | 10:05 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Good lord - are you trying to reach orbit?
Old Sep 1, 2009 | 10:30 PM
stonemonk's Avatar
Thanks guys, hopefully tomorrow I can get it together and try her out.
Old Sep 1, 2009 | 10:53 PM
1BADAIR's Avatar
the racetronix probably wont even support that
Old Sep 2, 2009 | 06:59 AM
Mike@HSW's Avatar
nice job, whats the motor setup?
Old Sep 2, 2009 | 09:11 AM
gvzo6's Avatar
x2 i have a simular set up but use a standalone
to support both kits ,do it right way ,dont risk it ,you will be better off good luck
Old Sep 2, 2009 | 09:22 AM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
What is that fuel solenoid good to. Looks like the size of our Brand X solenoids which max out at 200hp.
The fuel hose from the ZEX to the nozzle looks to be twice the length of the nitrous line. How is the lean spike if any?
Old Sep 2, 2009 | 09:44 AM
1BADAIR's Avatar
i have the racetronics kit. on a 100 shot it would loose 10psi and never recover
maybe with an external regulator it would.
I didn't like the pressure drop and lean spike so I went if a hsw standalone
Old Sep 2, 2009 | 11:52 AM
swomp rat's Avatar
Looks very clean!!!
Old Sep 2, 2009 | 12:27 PM
Cliff's Avatar
Where is your HSW standalone hooked into? Your pictures show your fuel coming off the fuel rail. Have I missed something? I would be scared to run two stages off the stock fuel rails.
Old Sep 2, 2009 | 05:35 PM
stonemonk's Avatar
Thanks, its a cam only ms3 car w/ most of the bolt ons.
And I am running a nx fuel noid, i called tech yesterday and they said it should handle a 250 shot.
As stated I need a stand alone, the most I will push it w/ the racetronix w/ hotwire is the 200, I'm also in the process of hooking up the FPSS.
Old Sep 3, 2009 | 07:08 AM
NXZ28's Avatar
I have the same kit. Did you make sure that the fuel side on the rear lines are flowing well? I put mine like that at first and the back two fuel lines just trickled fuel. I had to move the distro block to the center of the intake and even the lines out a little.
Old Sep 3, 2009 | 10:45 AM
stonemonk's Avatar
I was actually worried about that, as I didn't run the lines. How were you able to test that, I'd like to try it. BTW you have a pm....
Old Sep 3, 2009 | 10:21 PM
MelScrilla's Avatar
damn that a sweet setup but the 2 systems seem like a little overkill without even having a forged bottom end.
