Anyone experienced on fixing Solenoids?
What tool, other than a NX solenoid tool to use to get the tower unscrewed from these beautiful new NXL rails?
Why, what, would casue BOTH fuel solenoids to stop working. I can see some dirt making the soleoid stick open, but CLOSED, and BOTH?
Is the Oring reuseable? If not, is it a common rubber oring?
Troubleshooting, the electro magnets work, I tried the fuel side on the Nitrous Towers and they pulled them open, but no matter what the fuel tower would not allow the piston up inside!
The first thing you should check is the wiring and make sure it is not a bad connection.
If you do not have a spanner wrench to take the solenoids apart you can take them apart by taking a big pair of vise grips and grabbing the solenoid stem by the base of the threads, (DO NOT CLAMP THE VISE GRIPS DOWN BELOW THE THREADS OR IT WILL CRUSH THE CHANNEL INSIDE THAT THE PLUNGER GOES UP AND DOWN IN AND THE SOLENOID WILL NOT OPEN). If the stem was loose when you got it there is a possibility that the spring that goes into the bottom of the plunger as fallen out and turned sideways and this will not allow the plunger to lift.
If you have any questions feel free to call me at 903-565-4245
Robert Lane
http://www.fastlanenitrous.com
Thanks,
Charlie
