couple dumb questions N2O?
Ok i am bout ready to start installing my nitrous kit and i have a wilson manifolds single plate with big noids and probably going to run a microedge + progressive controller.
I was curious as if there are special relays that i need to run and is the nitrous and fuel relay the same? i plan on shooting 175-250 progressed.. Also what fuel pump and regulator do yall recogmend i have had a couple guys tell me that a holley blue pump is a good pump but idk! (Its a standalone System)
Thanks
Ray,
Thanks
Ray,
LS1TECH Sponsor
The solenoids will wire in to a single relay. The solenoids will require 25-35A maybe more depending just how big so get a relay good to at least 40A.
i plan on shooting 175-250 progressed.. Also what fuel pump and regulator do y'all recommend i have had a couple guys tell me that a holley blue pump is a good pump but idk! (Its a standalone System)
A Holley Blue will work just fine,especially with a low pressure return regulator, but be sure you get low pressure fuel jetting.
Thanks
Ray,
Thanks
Ray,
Thanks
Ray,
Thanks
Ray,
Just use an automotive style 40AMP relay for both. Make sure you also use an inline fuse as well for both.
Nick
