wanna see what lean and to much timing does to a piston...
Old 09-24-2009, 12:44 PM
ATVracr's Avatar
Originally Posted by Noyzee
rich is what usually gets the ring lands.
looks like the pistions took most of the pain, looks like the block may still be in ok shape and reusable with minimal clean up?
Block is fine.
We will have it up and running next week sometime.
Old 09-24-2009, 12:56 PM
SMITH's Avatar
i feel your pain. good luck on getting it back up and running.
Old 09-24-2009, 01:05 PM
ATVracr's Avatar
I talked to Prock today. He said ....
I'll call you later and give you the run down.
Old 09-27-2009, 11:50 AM
Gforce Engineering's Avatar
Ouch! I'd say it got really fat, lifted the rings then started eating itself over several outings.
What coating are you using on the bearings? My last 3 motors have all failed from rod bearings. Last one got about 20 passes before it siezed a rod bearing with a 300 shot. Took out 3 rods, 2 pistons, crank, block and a couple valves @ 140+ mph.
I did manage to save your old cam though
Old 09-27-2009, 04:29 PM
ShiznityZ28's Avatar
Originally Posted by JAX04
WOW, thats pretty, lol. well atleast you got a good season out of her anywayz.
what kind of piston is that?
Were not done. we got 4 spares and new rings on the way. we will be back out 2 weeks max....
Old 09-27-2009, 04:31 PM
Ill find out tomorrow who's bearings they are i now there coated and look dark black .Ill post up after i talk to the motor guy...
THe motor has never been run richer than 12.4......
Old 09-30-2009, 11:51 AM
BigDB's Avatar
sorry to hear but like u said **** happend when u push em hard. Build run blowup rebuild repeat
Old 10-05-2009, 02:03 PM
LS1RedZ's Avatar
Damn.. I burned a hole straight through mine lol
Old 10-05-2009, 04:50 PM
Nitro Dave's Nitrous Outlet's Avatar
You know what they say........
Lean is mean until it is no longer mean because it was to lean..LOL
