Dual wet nozzle jet ?
Also what plugs do you guys use with your 125-175 wet shot and what gap, i'm curently runing NGK TR6.
Thanks
You run the risk of adversly affecting distribution if you do. A nozzle was intended to be placed in front of the TB to give the mixture room to fully atomize the fuel.
But any way i talked to my local speed shop guy and got the jets figured out..
There is a reason why our LT1 plates are designe the way they are and why people are safely spraying over 200 on the stock LT1 intake with our plate.
Why risk it? If you are going to use a nozzle or nozzles place about 3 inches before the throttle body and give the mixture time to attomize into the airstream. If you want the plate look by one of our plate conversions. Our plate conversions are cheaper than a motor.
Just my 2 cents.
Dave
If you like the look of having the discharge behind the throttle body you need to use a product that is designed properly for the job.
Does not matter to me what you do. Its your motor. I am just trying to share with you the education that years of experience, R&D and testing has given me. I spent lots and lots of money for knowldge I am telling you for free. Use it or not does not matter to me. I am just trying to be helpful.
Im simply saying keep what you have with the nozzle in front of the throttle body. No money spent and you have a method that will produce better results than buying a poorly designed plate that places the nozzle you already have behind the throttle body.
Dave
