How does this wiring setup look?
the WOT can go any where on the low amp side of the circuit...which is the pin 85/86 side of the relay.
that side of the circuit controls an electromagnetic switch inside the relay. When you energize it it completes a circuit between 30 & 87 this allow the solenoidsto pull high current straight from the battery and not through your switches.
