Car barely starts after plug change
Old Oct 4, 2009 | 11:47 PM
TA1364's Avatar
Default Car barely starts after plug change
Im guessing this isnt normal after installing tr6s gapped 35? Its throwing a code but not sure what it is yet.
Old Oct 4, 2009 | 11:49 PM
lemons12's Avatar
Just went from tr55s to tr6s last night.. Believe my gap was at 32... I had to unplug my computer to run my nitrous line and when I first started it wouldn't run.. Unhooked batery for about 15 seconds and then it started right up.
Did you work on anything else? Any sensors unplugged?
Old Oct 5, 2009 | 12:16 AM
Nitro Dave's Nitrous Outlet's Avatar
Sounds like either you do not have a plug wire on all the way or you cracked the porcylin on a plug.
Dave
Old Oct 5, 2009 | 12:37 AM
lemons12's Avatar
Dave
It would start and run but just run like **** though, correct?
Old Oct 5, 2009 | 12:48 AM
Yes you are correct.
Old Oct 5, 2009 | 07:41 AM
TA1364's Avatar
Once it starts it seems to run fine, it just has hard time firing.
Old Oct 5, 2009 | 09:11 AM
SuperSlow02's Avatar
should run perfectly fine....did you unhook the coil packs on the pass side..I forgot to hook mine back up once and just couldnt figure out why it was being a turn....4cyl mode ftw
Nick@HSW's Avatar
What code is it throwing?
Nick
Old Oct 5, 2009 | 10:01 AM
TA1364's Avatar
Fired up fine this morning. Not sure what the deal was last night. Code is a broken temp sensor.
Old Oct 5, 2009 | 11:12 AM
Adam86's Avatar
Have you driven it yet? Might not run like **** if it's not under load. Once you put it under load it might start to sputter.
Old Oct 5, 2009 | 12:00 PM
ShiznityZ28's Avatar
Broken temp sensor is going to put fuel in it cause of the default temp. Fix the sensor and have the tuner lean it out a bit more at idle and put 3-4 degrees in again at idle. it will run better than ever.
Old Oct 5, 2009 | 03:45 PM
TA1364's Avatar
Yes it drives fine, no sputtering. It was running extremely rich that must of been the problem, makes sense now.
Old Oct 7, 2009 | 12:49 AM
1BADAIR's Avatar
it was adding fuel for like -40 temp
Old Oct 7, 2009 | 12:30 PM
Nick@HSW's Avatar
Sounds like maybe the connector was damaged? I see it happen alot with header swaps and plug swaps.
Nick
Old Oct 7, 2009 | 01:05 PM
TA1364's Avatar
Yea the plastic that the connector snaps on to was bent over and you can see the wires. I got a new one going on today.
