Single nozzle vs plate system
Old Oct 19, 2009 | 02:49 PM
vicouSS00's Avatar
Originally Posted by transam69230
I have been thinking about selling my 92mm single stage plate. If your interested maybe we can work something out!
pm sent
Old Oct 31, 2009 | 10:27 AM
samson_420's Avatar
Plate is really the only way, I think now. . . Since I blew my last motor when my nozzle decided to turn on its own. . . Plates just seem like a way better way to go, since the distribution looks a lot more even.
Old Oct 31, 2009 | 11:06 AM
TA1364's Avatar
Is there any ET and MPH difference between the two?
Old Nov 24, 2009 | 05:55 PM
john563's Avatar
anyone else have this happen with a nozzle
Old Nov 24, 2009 | 07:27 PM
JL ws-6's Avatar
Race your car!
More people then you wil find on here to post about it.
That's one of the reasons when the tnt power ring came out it was so popular, the nozzles in that didn't move on people. That, and their jetting was advertised as 100hp, was 4 sizes bigger then anyone else's 100 hp LOL.
Old Nov 24, 2009 | 07:31 PM
john563's Avatar
k sounds good! plate it is then!
Old Nov 24, 2009 | 08:11 PM
stewaj11's Avatar
I dont mean to jack your thread but i'm lookin to do the same change from a nozzle to a plate. Where would I pick one of these up? and how much does it cost typically to convert over? I have a ls1 with a 78mm throttle body.
Old Nov 25, 2009 | 04:35 AM
JL ws-6's Avatar
Race your car!
one of the sponsors, harris, nitro dave, Nos sells a plate that will work too, just look around.
Old Nov 30, 2009 | 11:51 PM
tekno66's Avatar
Couldn't you drill and tap the TB to install the nozzle? If you decided to run NA it would ruin a good TB though...
Plates look cleaner. Tapping the TB would look clean too. I never liked the idea of plumbing the nozzle in the rubber bellow, but it has worked for alot of people when installed correctly.
Old Dec 1, 2009 | 06:04 AM
JL ws-6's Avatar
Race your car!
Problem would still be distribution. The nozzle, unless in the perfect height/placment, would end up having distribution problems, as it would be aimed at one of the runners, hammering that one cyl. harder then the rest.
If, you had a single nozzle in the TB aimed wrong and it was shooting a 150 shot right at one of the runners, you'd end up putting probably 75 hp worth of nitrous into 1 cylinder...... think of that as if you were doing that to all 8, that would be hitting that one cyl as hard as if you were putting 600 hp of nitrous to the entire motor. Which sure, you can do, but the life expectancey, of a properly built motor is somewhat limited with that.
On a stock shorty... a 600 shot, yeah I don't think that would make it past the 300 foot mark without hurting something. So doing the same thing to 1 cylinder, isn't going to work.
Stock pistons, really need to have the distribution and tune up good to survive for any period of time.
Old Dec 1, 2009 | 09:53 AM
Nick@HSW's Avatar
Originally Posted by JL ws-6
Will it flow that much, yeah probably. would I trust it to deistibute evenly to all cylinders being a behind the TB plate deisgn that is dependant on the intake to do the distribution? Hell no.
Sad part is I have a gut feeling in a few months people will be asking questions on this forum as to why their motor blew up while running a 300 shot through the front of an efi intake...
Nick
Old Dec 1, 2009 | 11:21 AM
  #32
JL ws-6's Avatar
Race your car!
I'm sure it's going to happen. They're gonna wonder why they blew the car up, and they'll have been running pump gas with a tr6 plug too.
It's not that the right information isn't out there, people are just too damn stupid to listen most of the time. Every now and again you get a guy that will listen, but for every one that does listen, there's 50 that don't
And people wonder why nitrous has a bad rap.
Old Dec 1, 2009 | 11:48 AM
  #33
w3s1c0a5t's Avatar
How much better is the distribution of a plate over a good set up twin nozzle?
Still in front of the efi intake.
Old Dec 2, 2009 | 03:05 PM
  #34
87silverbullet's Avatar
Been there, done that. There is no comparison, the plate works a whole lot better than any nozzle. I had a 2 stage nozzle setup and it was a pain to get right, went to the plate and it made it look so much cleaner under the hood.
My 78mm 2 stage Nitro dave plate is for sale. Goin bigger and badder
Old Dec 2, 2009 | 10:39 PM
  #35
w3s1c0a5t's Avatar
What was a pain? how did your plugs look as far as ditribution?
Old Dec 3, 2009 | 06:48 AM
  #36
The nozzles were a pain to keep straight. Even with the nut that goes in the boot, the nozzles kept turning. When hitting the spray to make sure the stages work, the plate made the motor rev harder even with the same jets in it. If the nozzles turning wasn't bad enough, they would flex in the boot when you hit the spray, so they would end up spraying on an angle.
The plugs looked good with even distribution to all cylinders but that was on the first stage of a 100 shot. Only hit the 200 shot one time and spun a bearing so now I have alot of ls1 parts for sale.
Old Dec 3, 2009 | 06:44 PM
  #37
gsxr1k2's Avatar
I could'nt agree with you more but I also think you guys need to take a step back and remember for every good thread with solid info there's 10 bad ones on this site. This place is littered with bad info and when you use this site as a textbook bad **** tends to happen.
Old Dec 30, 2009 | 01:41 AM
  #38
DRTWRK1's Avatar
HI,Do you still have this plate 4 sale? thx Ron 719-821-1086.
