Nitrous issues spraying off the line, need assistance (Video)
if your bottle is oriented like this, than you need a tilt angle smilar to mine.
the wb is never the only measuring tool you should use, especially if you don't have tuning software to data log. reading each spark plug should be your reference to gauge how well the w/b is working. if i was spraying huge shots, than checking the plugs is a must.
the n2o noid draws a lot more juice then the fuel noid and, so, if the circuit is not a clean one the n2o noid will have trouble opening where as the fuel will not. i'm a nitrous rookie and these are the problems i have had.
With a full bottle the angle doesnt mean much, I doubt thats the problem.
Wideband is 1 sensor giving you and average of 1 side of the motor.
So #1 cyl. could be 10:1 and #7 cyl. could be 15:1 giving you an average of 12.5:1 see the problem. Then you have NO idea what the other 1/2 of the motor is doing.
Where should the A/F be if all the plugs are looking like they should?
Again, I'm going to switch back to the 75HP jets and see what happens. If it runs clean then I'm really going to be confused as it just doesn't make sense why that would work and not the 100 jets.
SPRAYIN96TA - I do not have problems taking the car to a nitrous specialist however I don't believe the symptoms will be easily repeatable unless done track side.
Please don't take comments as I'm arguing but simply discussing the possibilities of what's going on here. Bottom line is nitrous is not flowing like it should right after the launch and I think it may be a leak somewhere or lack of flow somewhere in the system.
