You think this will work?
Old Dec 7, 2003 | 10:27 PM
StupidFast's Avatar
Default You think this will work?
I want a direct port. However, I don't want the fuel cell, extra fuel pump, or the extra fuel lines. NX makes a kit that will work with our high fuel pressure but, it is designed for a returnless fuel system(F-body).
My buddy was thinking that we could just install a fuel pressure regulator on the service port on the fuel rail. Then just run a line to the fuel solenoids. You think this will work? I have plenty of room under the hood for this crap and both of my fuel pumps should support any amount of reasonable power. I want to run a 175 shot direct port setup.
What do you think?
Old Dec 7, 2003 | 11:28 PM
Steve@SpeedTech's Avatar
NX makes a couple of different direct port set ups for EFI fuel pressures one of which is for the LT1/LS1 cars and another that is for other EFI vehicles which would work for you. It could be set up much like you mentioned in your post. If you would like some prices feel free to email me at sales@speedtechnologies.net or call me at 417-581-1175. I would be happy to work with you to make sure we can get you a system that will get you the performance you and that you will be happy with. Thanks
Old Dec 8, 2003 | 12:33 PM
StupidFast's Avatar
I called NX and NOS they both said that they didn't make a kit that would bolt on my truck.
I was going to buy a NOS Sportsman kit and install it on my truck. I just need low fuel pressure.
Old Dec 8, 2003 | 12:57 PM
That's correct its not a direct bolt on like the NXL systems but NX does make a direct port system that works with EFI fuel pressures. It would be a similar installation to the NOS Sportsman but would not require a seperate fuel system. Wth both the NOS Sportsman and the NX EFI Direct port systems you would have to drill and tap and plumb your intake.
