forged 408
What heads are on it, because you'll have issues lifting a stock type casting due to the thinner deck not sealing as well.
Turbo/supercharger's dont' tend to have the same problems with the motor that nitrous creates at the same power level. Meaning, a 408 that's making 650 to the tires yeah you'll be fine simply because the engine is big enough and pretty much any aftermarket parts will hold up to that level.
Try to push it towards 1000 hp, and you're in a different realm of issues, FI causes some, nitrous causes others.
I dont know what dish you have on your pistons and what cc heads it would take to bump your compression but I would look into that first. You might be able to trade shortblocks with someone looking to FI if you dont want to go into changing things on yours.
Jim C.
PS - What are the specs on the camshaft.
Jim C.
