My Nitrous Nozzle
Old Nov 7, 2009 | 10:36 PM
WS.666's Avatar
Default My Nitrous Nozzle
Sooooooo...I went to install my nozzle in my silicone coupling using the Nitrous Outlet adapter and discovered that it did not allow the nozzle to go more than half an inch into the tubing. Since the nozzle sprays at a 90* angle, I was thinking that about half of the Nitrous/Fuel mixture would end up on the tubing, rather than in the intake. So, I did some thinking, some measuring, some cutting, some more measuring, some drilling, and finally some installing. This is the result:
When I put the nozzle in the tubing, it was not very sturdy, and I think that if I when I went WOT, the incoming air would dislodge the nozzle and bad things would happen. My solution was to drill 4 holes in the tube and use them to attach fishing line to the nozzle in order to keep it mounted firmly and centered. I tested the line fitting before I siliconed the nozzle in...I think I will have to mount something to hold the upper radiator hose down half an inch, so the lines can fit comfortably, but I don't think it will be a problem.
Oh, and the whole reason the nozzle is mounted where it is, is because I wanted the stealthiest setup possible...the tank is in the spare tire area, the buttons are in the ashtray, the electronics are in the console, the solenoids are under the cowl, the lines will be covered with wire loom, he nozzle is under the intake coupling, and the purge is on the nose, rather than the typical windshield cowl.
Old Nov 7, 2009 | 10:50 PM
jmill96Z's Avatar
Is this serious? If you have a backfire, the fishing line is gone. I hope it works for you, but maybe think about some .020 safety wire if you're hell bent on this setup.
I do not see good things coming of this man.
Old Nov 7, 2009 | 10:57 PM
WS.666's Avatar
If I have a backfire, I've got bigger things to deal with.
Also, this is why I posted here...I'm looking for opinions. I was actually considering some metal wire, but I didn't want to buy any yet, so I used what was sitting around. That being said, thank you for your observation and suggestion.
Old Nov 7, 2009 | 11:00 PM
01FbTaWs6's Avatar
i think I honestly would have just mounted the nozzle the way you had it in the first place.... Never seen such a contraption.
Old Nov 7, 2009 | 11:51 PM
mitch cobb racing's Avatar
i can see where youre going with this... but i bet they did it the way they did for a reason.
Old Nov 8, 2009 | 03:10 AM
SPEED#1's Avatar
I would mount it the way it was suppose to be, that why they MADE it that way. They know what works and what dont!!!
Old Nov 8, 2009 | 08:49 PM
Fury_786's Avatar
mine works just fine the way it was made...you're gonna fukk something up bigtime.
Old Nov 9, 2009 | 02:31 AM
BobDoLe's Avatar
that fishing line and silicone is not going to keep that nozzle from dislodging. when you activate the nitrous, the pressure is going to send that **** flapping around in there violently.
you could look into a 70 degree nozzle
http://www.harrisspeedworks.com/prod...&cat=10&page=1
Old Nov 9, 2009 | 10:04 AM
Nick@HSW's Avatar
Yea not a fan of the fishing line. I'd hate to see any one part of that get sucked down the intake.
Nick
Old Nov 14, 2009 | 08:30 PM
LoudGM's Avatar
maybe its time to get a plate.....haha
Old Nov 15, 2009 | 05:56 PM
02 BLK WS6's Avatar
Eggzachary!
Old Nov 15, 2009 | 06:14 PM
Fury_786's Avatar
or just use the system he has the correct way...most people who run 100+ shots like a good nozzle over a plate anyhow.
Old Nov 15, 2009 | 06:27 PM
vicouSS00's Avatar
Really? Never heard that before, guess i'll see after i spray my plate in the next week or so for the first time.
Old Nov 15, 2009 | 06:32 PM
Fury_786's Avatar
ive seen a ton of posts about plates being restrictive over a 100 shot.
i run a nozzle and a 150 shot and it works great.
Old Nov 15, 2009 | 08:55 PM
uh huh............
Old Nov 15, 2009 | 09:02 PM
kinglt-1's Avatar
Old Nov 15, 2009 | 09:56 PM
camscam02's Avatar
hahaha add that to the most ignorant statements thread. lol
Old Nov 15, 2009 | 10:01 PM
i was gona copy/paste it over there, but decided to be nice
Old Nov 15, 2009 | 11:18 PM
Fury_786's Avatar
oh thats right...i dont know anything about nitrous...
just because i have a low post count here doesn't mean im ignorant, asshats
Old Nov 15, 2009 | 11:24 PM
us giving you a hard time has nothing to do with your post count, i didnt even notice until you just said it... its because what you said is completely ridiculous!!!!!!!
