Teflon paste
Should I use Teflon Paste on the threads on the Blow Down tube fitting that goes into the bottle? Everybody says not to use the tape so should I use the paste or are the fittings ok to use without anything and wont leak? Where do you but the paste? auto parts stores carry it???
Thanks for your replies!
James
James
I believe his question is not about the fitting where the blowdown tube screws on, but the other side of that same adapter. The 1/8"NPT threads that screw into the bottle valve. I have always used paste there ?
