dry nitrous tuning
If you want to mess with fuel and timing use the coolant sensor and a relay with a resistor to put your coolant sensor(100,000 ohm -40c)(53,000 ohm -30c) reading where you want ,then modify the tables accordingly. Use the power enrichment fuel adder vs coolant temp to add fuel and the ect spark advance correction table to pull timing.
so, if you go driving around and floor the throttle off the bottle, it's going to give you the higher timing in the upper part of the table (lower grams/cylinder values). it is like having two tunes (optimum NA and optimum spray) loaded.
i have the interface, but i still use this same method to pull timing as i feel like it gives me more control to make adjustments to timing at different RPM while spraying.
Once you log your sprayed and non sprayed runs, you will see the separation of the two. Actually for most the spray starts around .96 to 1.00, but we dip a little lower for safety, if we want to. So what I am saying is N/A only sees to .84, but spray starts at .96 . Dropping down from the spray start point is a good idea, IMO, but not absolutely mandatory. Staying out of n/a territory is what most want to do, I didn't care if I got in to it a little because I don't race n/a. Hope this cleared things up?
Robert
That's what I have been saying for years "Two Tunes in One", and the reason I love the dry technology. With guys like yourself that actually understand the workings, it is starting to take off more than ever. So many ways to skin the dry cat these days, choices are great though.
Robert
How do you tell the pcm to run the nitrous tune using efi live? This would be a cool feature. I had a stage 3 pcm in my Cobalt that you could run a 50 shot. All you had to do was add a wire to the pcm and have the nitrous activate it. It also had a race gas 100 octane tune and adjustable rev limiter.
On a side note....
Don't see how my method is hacking a tune but whatever.
The EFI COS 5 is really no different than any of the other sister controllers, or Tuning with HP Tuner. They access and change the exact same tables, however, it is very nice having it built into the tuner program (hopefully, HP Tuner is listening and adds something similar?). You do know that wiring and hacking into the cars system/wiring needs to be done for the trigger to work . This can be a pain in the arz, in and of itself. I haven't done it myself, but Beer did a little how-to and explained things and went on to say that is was not as easy as one would think (maybe someone can find beer and have him link it, for more insight). I thought it to be a breeze, and he corrected me and said, not so. That is the trigger part, the software part wasn't anymore difficult than say setting up HP Tuner, or the Interface, IIRC.
They all take control and trick the computer into doing something it would normally not do. Now with that said, if one has EFI Cos 5 already, yes that is the best and easiest route to take, IMO, so I agree. The HP Tuner timing pull write-up was for guys that may already have the program, not meant to insight going out and buying the program just to be able to tune this way, just another alternative for some. In the beginning, that was really about the only way to pull timing with out a piggy-back controller of some sort, and for the dry hits only.
Robert
Robert
Robert
with the iat circuit open during solenoid operation,fuel is added with eq ratio modifiers along with timing retard that changes along with rpm...
as you know,those tables are extremes the engines will not see in normal operation...
doing it this way allows me a motor tune and a n2o tune at the same time,just like that cos#5...
i just started messing with it this week and found out quick,E85 and a dry setup needs quite a lot of injector...
my 57lber's ain't gonna cut it...
so back to gasoline for the time being...
just running 1 stage for now until i get a handle on the tune,then cut in the second stage...total shot will not be much as i only ran a 150 shot wet kit before about 4 years now...
i am just curious if i can dial in the 2 stages where i could run both at once or separate depending on how i feel...
I sure wish we had E-85 around here, but we none at all, damn. But like your state, it needs a lot more fuel reaching the cylinders compared to gasoline. The tune really needs to be adjusted at a few parameters. What is it, 30/40% more? or close to that? But in the long run, due to the better octane rating, the E-85 may just be the future of the dry hit, at least where you can get it. Hopefully you can get some injectors and keep us apprised on how to set-up up a Dry E-85 system.
Talking about fueling the dual stage dry, and timing for that matter. Currently I am running redundant InterFace controllers. The accumulative affect works wonderfully. I can have 1-stage, 2-stages or just the second stage. All automatic on the timing and fueling. A great system that has so many adjustable features. Then in each Interface I can change the timing pull by flipping a combo of dip switches. So in my notes (for those that have early onset old timers...) I look at what combo of dip switches allows for targeting XXX temperature in HP Tuner (advanced Interface mode). Then in my HP Tuner I have set-up the target temp to be a true timing curve as one of my dip SW combos. This one is my aggressive tune, I pull max timing at my torque peak, then after-wards I start adding timing back in all the way to red-line. A true custom timing curve. So you can see the combos are endless. Actually, I have a 3rd stage tied into this too, but won't go into that now. I guess my point here is this, we can fuel and time a dual stage really easy with the Interface, and also with other piggy back controllers I am sure (can't think of one currently, but...).
Before the Interface, timing and fuel worked as the accumulative mode a little differently when I had the before the MAF quad nozzles, but again won't go into that now or here (we now run all 3-stages post MAF). But will say it was all tuned with HP Tuner.
We kind of jumped all over the place, but hopefully there was still some usable information to give some ideas on how one may like to approach their dry tune.
Robert
the only pita part was to find a PCM pin to pin into the pin 56 on the red pcm connector... But I took out my A/C so I disconnected the A/C wire (forgot which one) and i re-used that pcm pin
the only pita part was to find a PCM pin to pin into the pin 56 on the red pcm connector... But I took out my A/C so I disconnected the A/C wire (forgot which one) and i re-used that pcm pinThe .50 cent connectors are readly found here
http://www.eficonnection.com/eficonnection/100w.aspx
C-5 guys have it made, for setting up Fuel pressure and nitrous pressure sending units through the unused EGR PCM pinouts (5V power, Ground, Sensor voltage).
ur no monkey...
Actually Robert, I was more like one of the first ones publically looking for info on it, and posting what I could as I learned. Minitrkr was a big help through PM's and had success with it long before I.
Heres some pics, and screens of some of the menu's. I have only dabbled with this with 50 and 100 shots, but now that I am having to pull my motor, I will have the forged goods and nads to spray some mo healthy shots.
The .50 cent 18 Gauge connectors w/ Soldered wire to em.
Pin 56 on the 99 PCM. Basically take a big *** needle and break that yellow rubber seal, then insert the PCM Connector in, You may have to use the big *** needle to help push the Connector all the way down, but you will hear it snap into place.
COS 5 Menu's
COS 5 Nitrous functions are not tricking the timing using IAT tricks, pretty much if Pin 56 is grounded (and the valet mode parameters are set correctly), it will use Nitrous Timing and VE multipliers.
Below, when the table is active, it pulls timing per the values in the table
Below VE multiplier, here what I was trying to do, was account for the lean spike (caused by fuel pressure drop), and then it richens, so I use the VE multiplier to try and get around the lean spike, then lean out what usually ends up rich in the upper RPM. I have not tried this yet, but will in 2010.
My question is. While using resistors or diodes or what ever, or wiring into the car's PCM, just to tune for the nitrous hit - isnt it easier to just use the HSW Interface? Plug it in - hook up a couple wires to your controller, and you're done... Seems easy to me... But I'm a noob, so I'm still learning...
Thanks
Thanks
In my case, the Interface was not available when I purchased EFI Live (three to four years ago). Being the software was purchased in my case, I could not justify shelving EFI Live and purchasing the interface. Matt and HSW pretty much came out with new cool stuff, right after I purchased what was available at the time (their electronics, their Plate System etc...).
EFI Live is great for logging the runs and wiring into the PCM for logging fuel pressure (using the EGR pinouts) and recording bottle pressure, as well as relay status makes looking at and troubleshooting each run a breeze.
Thanks
, im tuned in OLSD so it wont wrk since i have no MAF Robert
